Electrical Engineering & Electronics Design
Created by Xgentec Jason on 11 April, 2018
Hello everyone.
I have created a frequency output delay formula from scratch.
I told the Arduino IDE to output a PWM signal from 0 to 500KHz using a STM32 microcontroller.
As you go up higher in frequency the output delay time on the microcontroller output gets higher. For instance if you request 500 KHz you get a delay time and the actual output is 380 KHz etc...
I have attached a picture of my oscilloscope data readings on an Excel graph with a formula to predict this delay time.
This formula matches the output data response from the (real world) oscilloscope readings virtually exactly.
Yes I know my math skills are not the best on the planet in fact I know they are my worst area so I thought I would reach out to get others to double check my formula.
Orange line is oscilloscope readings reading the delay in output.
Green Line is the delay time prediction formula.
