Electrical Engineering & Electronics Design
Created by Xgentec Jason on 11 April, 2018
SolidWorks PCB server "Push server error: StatusCode: 500, ReasonPhrase: 'The type initializer for 'ExtentPlaceholderCreator' threw an exception." Error
I want to make the PCB with Altium and send it to solid works. I did the same thing a year ago on the same computer that I am currently using, but today when I try, I get the following error. I didn't remove any software, the old software is still there and there is no problem except this below issue.
I want to make the pcb with altium and send it to solid works. I did the same thing a year ago on the same computer that I am currently using, but today when I try, I get the following error. I didn't remove any software, the old software is still there and there is no problem except this below issue.
The problem is with the SolidWorks PCB server. If you try to make a change to a project or create a new project, the following error will be displayed. The picture below shows the error that occurred when trying to push the board to the server in a previously made project.
