GrabCAD Russia
Created by Виктор Васин on 12 June, 2018
how convert (STL/OBJ) to (SLDPRT)?
STL/OBJ it just a mesh object. You can open it in SW and save as SW part detail but it will be no editiable object. Threre is only way to convert mech object to surface/solid body - reverce engineering. Reverce engineering is procedure when you manually recreate solid body using a mesh file
