Mechanical Engineering
Created by tomas omalley on 14 June, 2018
Any better idea for this process?
Hello,
Hopefully everything goes well with you.
In the attached video, you will see the filter plate is taken back one by one , it takes a lot of time, especially for the big machines with hundreds of plates...... There is a quicker way that we will link 3 plates with a chain, the trolley will take 3 plate one time, but still not efficient enough and you will need more space for it( space needed to make sure the stuff between the plates will fall down automatically)
I would like to improve it by updating the structure, completely if needed. Could you please share your idea about it? Thank you!
Btw, you may get more info from the internet by searching words "filter press", thank you.
