Designing 3D models for Robots/Machines
Hello Everyone, I hope all is fine
I want to Design 3D models for Robots/Machines such as 5DOF Robots, CNC machines, Laser machines, drilling ,.... etc
where i can get the dimensions ? is there is any website i can download all parts dimensions from ? or a Book cointains large assembly files with dimensions?
Thanks in Advance
You aren’t “designing” these machines if you download all the dimensions off the web or copy them out of a book.
If you “design” these things then you create your own sizes and dimensions.
It generally starts with whatever standard components you decide to use. Motors, bearing, shafts etc. you design your components to fit these standard components. The dimensions follow from that process.
