Give me Advice
hi ı am eyüp. I am new mechanical engineer. can you advice or suggest me to improve myself for mechanical engineering?
Accepted answer
I'm an old school type engineer. When I design something I usually try and build a mock up of the unit. The other thing I did was to work in the environment the design is for to get a better understanding of what is needed and what is not. When I wanted to do architecture I got a job in house construction, that way I understood the building requirements and limits of building on site. Think of ways to limit complexity of the construction and ways to reduce costs via materials or labour.
1 Other answer
Hi Eyup!
Are you in university and in which sem? Your area of interest?
In mechanical engineering here we have various options to choose from. Select your area of interest and then I can suggest you something. It would be better if you provided some more info but I know sharing info in the public group is not always a good way. If you want to discuss this further then let's have a discussion in my inbox.
Thank you
