Mechanical Engineering
Created by tomas omalley on 14 June, 2018
NX or Solidworks
which is better NX or Solidworks in assembly?. i work with solidworks since 2016 but i see a lot of comentaries about that NX its better than solidworks in the case of assembly
Accepted answer
Hello Eric!
That comparison is somewhat unfair because NX is a high-end application (which you could compare to CATIA, for example) while SolidWorks is mid-range (and it would be fairer to compare it to Inventor, SolidEdge, etc.).
Greetings
PS: I suggest you see my answer to the question: https://grabcad.com/questions/which-software-do-you-prefer-for-3d-mechanical-modeling
0 Other answers
