Hello everyone.
I have been considering starting a radio setup in my home electronics lab.
This is due to the fact I already repair electronics and repairing RF equipment on occasion is simply another challenge.
I am though extremely concerned about lightning strikes and what would happen if an outdoor antenna was hit with the coax going directly in to my lab.
I simply could not risk the consequences of that happening.
This guy had a lightning strike on his equipment. Did not end well.
https://www.youtube.com/watch?v=ABTyqL-8O_0
For this reason I am considering a loft antenna. I am fortunate as I have a loft space with a height of 4.5 meters !!!!
I was considering an inverted Vee antenna with balun design and have done all the calculations however with a loft space of 4.5 meters I came across this.
Sigma Euro-Comm 2011 5/8 wave Skip Master CB 26-30 MHz AM/FM
FIBER GLASS HOME BASE ANTENNA
Power handling 1000 watts
Length 4.35 m/14’ 3 inches
Gain 9.9 dB
Impedance 50 Ohms
Frequency 26-30 MHz (with tuning)
Construction Fibre glass
SWR 1:1.3
Mounting bracket pole
The Sigma Euro-Comm 5/8 wave Skip Master 2011 is a high performance base station antenna.
The top section has 2 tuneable whips which can be adjusted up or down to suit your desired frequency band.
The total bandwidth with tuning is 4 MHz, from 26 to 30 MHz. This makes it ideal for CB 10 Metre band as well as DX’ing.
The construction is 3 sections of fibreglass and 2 small stainless steel tuning whips.
The total length including the whip is 14 foot 3 inches/4.35m making it more stable in high winds.
Although the antenna is shorter in length than ½ wave Skip Master version, the coil design on the top section is reported
to achive 1 extra S point also there is less noise on receive than our Aluminium Venom base station antennas !
The 5/8 wave Skip Master fibreglass antenna is weatherproof to enable many years of use.
I really would appreciate secondary opinions and recommendations on this matter.
What do you think ?
If I tilt an antenna slightly 5 meters or possible 5.5 meters is possible. Although I understand tilting an antenna is not one of my best ideas.
