For those unacquainted with RF components, most of the parts are defined by deciBels (dB) for either Power (most common) or for Voltage in terms of gains or losses :
https://en.wikipedia.org/wiki/Decibel
A deci (1/10) of a Bel is used for Power since gains (or losses) are so large that they are in orders of magnitudes ( https://en.wikipedia.org/wiki/Orders_of_magnitude_(numbers) ) , and from the Power Equation P = V^2 * R, Voltages are in twice the orders of magnitudes of Electrical Power. This is because the log of a squared exponent is a 2x multiplier.
But where did all this start from one might wonder ? It started from fact that as waves move outward from a radiated source that the electro-magnetic wave has a diminished power directly proportional to the radial distance from the source. This is known as the Inverse Square Law (https://en.wikipedia.org/wiki/Inverse-square_law ) wherein the energy radiating from a source is inversely proportional to the radius squared, which is an exponent function.
So for RF energy radiating from a monopole or dipole omni-directional antenna ( https://en.wikipedia.org/wiki/Omnidirectional_antenna ) the RF energy will diminish closely related to the radial distance of the source (transmitter) to the load (receiver).
For a directional antenna (https://en.wikipedia.org/wiki/Directional_antenna ) the same philosophy still holds true, its just that the energy is focused in a particular direction and therefore will not suffer the losses as quickly.
