RC plane Design and build
Created by mohsen khalafi on 12 July, 2021
what is the easiest way to produce rc planes
I had tried multiple ways to build and I want to know how can I easily make them?
Accepted answer
Dear Leonardo
the way i approach this thing is that i usually to find or build a good shell surface design (i'm not a good surface designer) of the plane then define my size and scale.
after that i define the sections which i want to put my bulkheads there and from there either I go for a stringer and bulkhead structure or I use a box frame inside as the structure and just a light skin as the shape former.
wing design is always wooden built up rib and spar design which balsa sheeting .
2 Other answers
It depends what you mean by 'produce'.
Do you just want to make CAD models, or are you asking about building physical models?
