Sheet Metal Design
Created by Kyle Oickle on 19 June, 2018
How to add edge flange on radius cut SolidWorks2020
I want to add an edge flange to a cut out which goes through a radius in sheet metal solid works 2020. How does that work?
Accepted answer
check it. explanation below your post.
flat portion you can delete later when you do not need it anymore
2 Other answers
Insert- sheet metal-edge flange has to work. if your part already created as sheet metal , not supposer to be a problem. If not- go to the feature before cut-outs and insert-steet metal--bends. it will convret part to sheet metal.
After designing the radius as a loft bend I could add the edge flange
