Raul Santiago 22 Feb, 2023 11:15 PM I have problems with the "FLAT" and Bend Process.I need help with the following topics.*Gauge TableK factorAnd the folowing formula.ProgramID.ClassName:
Chad Billings Feb 22, 2023 @RaulThe K Factor is on the Gage Tab of the Material table. Only it's called "Neutral Factor" in solid Edge.I'm confused as to what you're asking for help on specifically. Yes, Flat's and the Bend Process, but can you be a bit more detailed? Log in or sign up to post a reply
