Can you give me some design idea regarding bending machine for
leg capacitor.
of course i already visited youtube but i just need also the details especially the exact material for bending.
Thanks for your prompt reply.
Number of pieces to be bent in production run? Physical size of bent part? Drawings help. Tolerance expectations? Form of bend? Available budget? Familiarity with cold working metal properties? These are all important details unless this is a homework assignment. More information required for better answer.
Hi Sir, thank you for your reply.
I'm just actually designing an auto cutting and bending machine for
capacitors.
Need some design idea and also materials to be needed. Again thank you for the reply, so much appreciated :)
Ms. Rodriguez you've not supplied any more information than your original post and not answered ANY of the questions I've asked. While I'm quite willing to advise your design as best as I can I don't think it's fair to others that actually do the research/homework to simply give you a design concept to run with. Asking for guidance or comparative opinions is fine, asking for the entire solution without demonstrated effort on your part denies you the chance to learn something besides how to get others to do your work for you. I've now spent twice as much effort in my replies as you have so if you can't be bothered to invest the time then I suppose I can't either.
Ms. Rodriguez;
I had you down as one of the lazy millennials I encounter all too often, I was wrong about you and must apologize. I'll need to examine your screen shots in more detail before I post anything but wanted to square up with you first.
Hi Sir, Its ok. I'm just having a second thought of sending my design since I think I must do it on my own but I really need help this time. I need to finish this layout asap. I'm looking forward for your reply sir, hope you can help me and give me some good advice.
Thank you.
I wrote a long reply but had an broken connection to the internet and it ate my reply. will have to re-type. An important question here, is this for school or an on the job project? This makes a large difference.
Sending the layout for a school project will depend upon what level of detail and feasibility is expected. Sending it for an actual job project may not be a good idea in the current concept as there are some areas that may not work well for production purposes. How much time do you have and who needs to review it? What is expected from you on this?
