Hi to all.
I have a 950 newton gas spring with a stroke of 40.0mm that I want to compress 30.0mm using only a 90deg rotation, but the linear movement sits 90deg to the rotational direction and I only have a bore size of 25.0mm to work with.
Note... the linear movement and rotation direction are not in the same direction.
