I modeled a bee hive. First, I creating one part file with all the pieces as configurations and then assembled the whole thing. After that, I exploded the assembly for the purpose of laying it out in a drawing.
I wanted to add labels to the separate pieces on the exploded assembly so that I could make a parallel table that would identify the part and its dimensions. I tried to insert the design table from the part file, but soon realized that it was not available because it was not created in the assembly. Also, It wouldn't have a column with vales (1, 2, 3, ...) linking to the labels on the exploded assembly.
There is a attached image example of what I'm trying to accomplish. Also, the part and assembly file are there if someone wants to check it out.
Any help will be appreciated.
~ Yann
