Can solid works perform simulation ie. Welding effect on bodies due to excessive temperature?
Solidworks cannot simulate thermal deformations during welding. They propose to make calculations in a specialized program and use the deformation plot for import.
Try something like SYSWELD - https://www.esi-group.com/products/welding-assembly
other software wich can do it - https://www.mscsoftware.com/product/simufact
https://www.simufact.com/simufactwelding-welding-simulation.html
Please can I use SOLIDWORKS for optimizing a solar water system to know what parameters would give me a certain volume of water?
Solids works can not calculate such fluid parameters unless if anyone has come across it, then educate us. But for solar water systems, I use PV syst software. Good for designing all solar projects.
Wow. Please can you help me run the optimization on it?
Well, what exactly are you looking for when you say 'run optimizing' ?
I want to have 20L of clean water from 25L of brackish or salt water at inlet
