When i try to convert my assembly in STL it render each part differently. Is there any way that i could open my assembly file in 3D without solidworks.
When you save the SLDASM file as an STL, choose STL as the file type then click on "Options" and uncheck "Save all components of an assembly in a single file" as in the attached images.
