Hi all
This one has me puzzled as I can't think of an easy answer.
I need to put 30 holes in a plate but the holes are all different sizes (A) and have a taper.
I have a few of these parts to make so I'm looking for an easy way to do it.
Thank in advance.
You can make a pattern of one Revolved Cut, then use the "Instances to Vary" option from inside the pattern's PropertyManager to change the value of both A & the Angle from one instance to another.
