SOLIDWORKS Design & Help
Created by Angel Ramirez on 9 March, 2018
How does this given 3/2 solenoid direction valve works?
I am somewhat good with concept of 3/2 (basic) directional valve, but I am very confused with this solenoid value- where should be the input and output. I don't see the ports in and out. Can you help me how this part works (https://www.mcmaster.com/1643N34/) and also this link will have 3D model. (https://workbench.grabcad.com/workbench/projects/gceCJGo5_I75TfslDacwVwsEnGvSHtqFa7EeY4xiBvLQSY#/space/gc9PIsU7Sf6ws6PGwjFGPvV_QLdvFj3HW0VMFexrzn1JbV)
It is made for a specific use; the ports are an opening at the lower end and the little radial holes separated by gaskets. The attached datasheet shows the details better.
