key representation on break out section view
Folks, I had bad times trying to create a broken out view to detail a key in shaft (the same representations showed in the image below). I selected the shaft to not be sectioned when I create a section view although I wanted to apply a small broken out view just to show the key but it doesn’t work because I have selected it to not be sectioned. I have tried to allow the shaft to be sectioned I then hide the hatch but it produces I weird result because some line which is supposed to be showed isn’t it. How could I solve that problem?
