Solidworks sweep feature creating problem
Hello,
i have noticed a couple times when i want to edit the sketch of a sweep feature, the points and lines tend to move uncontrollably when dragging them to a different area.
For example the file i uploaded, when i try to adjust the path sketch end point manually, the movement does not correspond to my mouse movement. If i delete the sweep feature and try to move the path sketch points, everything moves accurately.
can someone open and verify that it isnt just me experiencing this. i am using 2017 version. also is there a setting perhaps causing this?
