FredSWUG
I had some water/laser cutting shops not like my DXF files because they were splines.There is an option in SOLIDWORKS to export Splines a...
Thank you for such illustrated answer. BTW, did you accidentally spoted with "splines as splines" on your screenshot?
I have been tried different options to export DXF including those parameters in my SW15.
And even then I have only circular fillets going to export as "arc". Conic Rho and conic radius still exports as "spline". Merging does not change anything too. I try because sometimes there are requirements to export as closed loops, but that checkmark does nothing (even i set up 0.001 in input field next to merging checkbox).
I still doing everything manually reopening DXFs in autocad.
