can anyone help me in solidworks to be able to animate a rotor turbine any rotor turbine just want to get a tutorial on how to just make it rotate about the x axis
Rotor Turbine Rotation Animation
I believe if you apply the gear mates to the x-axis and the other x-axis of the force acting on the turbine, the turbine should spin. Also try your motion study animation.
If you have the program check the help in the software. It’s really good. And it comes with the program for easy access.
