can anyone help me with detail 2d drawing of bicycle chassis?
what should be the starting point for modelling bicycle chassis in CATIA?
I'd start with the bottom bracket, nearly everything else is connected to it.
You could start with the head tube, but it is more troublesome if you later change the head tube angle.
