Can I run my AutoCAD 2010 32 BIT software on 64 BIT laptop?
I have just upgraded my laptop from a 32bit windows 7 operating system to windows 8 64bit and now I cant install my AutoCAD 2010 software any ideas please. :(
You could use free Virtual machine software, such as VirtualBox, to host a 32-bit operating system inside of Windows 7 64 BIT. and install 32 BIT Autocad on it
http://en.kioskea.net/download/download-1329-virtualbox
http://www.microsoft.com/windows/virtual-pc/download.aspx
http://www.sevenforums.com/tutorials/8247-windows-xp-mode-install-setup.html
However, nearly all 32 bit software works just as well under Windows 7 x64.
thankyou CMED i,m not quite sure what the problem is , I just get the error message "cannot install this program on the current operating system"
I'm using that Longbow Converter tool... It specifically fixes that issue you mentioned "cannot install this program on the current operating system"
Here's the info on it... www.longbowsoftware.com/Converter.php
YES...!! A BIG YES. Now Look its simple no Compatibility software needed LOOK. Open where the AUTOCAD 2010 setup Folder CD, then Open Setup.ini (Configuration File with some GEAR LIKE).
On the middle you will see:
PRIMARY_MSI=acad\acad.msi
SETUP_ICON=SetupRes\acad.ico
x86_IMAGE_PATH=x86
x64_IMAGE_PATH=x64
CHANGE
x64_IMAGE_PATH=x64 to be: x64_IMAGE_PATH=x86
SAVE
RUN the SETUP AGAIN in XP COMPATIBLE MODE
VIOLA......!!!! it WORKED 10000% I DID THIS
SEE the attached IMAGE
