CATIA V5 : How can i remove all blades except from the encircled one and pattern that one in place of others.
This dump solid is generated from a STL and i am given a .STP file. I want all the blades to be similar to generate a reference model for modal analysis. I want the encircled blade to be copied all over rotor. Please guide how this can be done.
Thanks
Nouman; I've made a tutorial with all the steps to guide you through the process:
https://grabcad.com/tutorials/how-to-change-the-blades-on-a-dumb-solid
