CNC milling, how to avoid Z offset beetween each milling pass?
Hello, I'm milling countebore hole for shoulder screw on a small 3018 CNC.
I designed 2 hole using Vectric Aspire, one bigger for the head screw, one smaller for the shoulder.
Such paths have been outpout as one gcode path.
The problem is the Z always go back to zero origine beetween each path and I loose a lot of time.
Any idea how to avoid this?
Thanks
Accepted answer
The tool path plot before and after modification is as follows.
1 Other answer
T1
G17
G21
G90
G0Z2.000
G0X0.000Y0.000
S20000M3
G0X0.000Y0.850Z1.000
G0Z0.000
G1Z-0.148F300.0
G3X-0.850Y0.000I0.000J-0.850F800.0
G3X0.000Y-0.850I0.850J0.000
G3X0.850Y0.000I0.000J0.850
G3X0.000Y0.850I-0.850J0.000
G1X0.000Y1.850
G3X-1.850Y0.000I0.000J-1.850
G3X0.000Y-1.850I1.850J0.000
G3X1.850Y0.000I0.000J1.850
G3X0.000Y1.850I-1.850J0.000
G1X0.000Y2.850
G3X-2.850Y0.000I0.000J-2.850
G3X0.000Y-2.850I2.850J0.000
G3X2.850Y0.000I0.000J2.850
G3X0.000Y2.850I-2.850J0.000
G1X0.000Y3.850
G3X-3.850Y0.000I0.000J-3.850
G3X0.000Y-3.850I3.850J0.000
G3X3.850Y0.000I0.000J3.850
G3X0.000Y3.850I-3.850J0.000
G1X0.000Y4.850
G3X-4.850Y0.000I0.000J-4.850
G3X0.000Y-4.850I4.850J0.000
G3X4.850Y0.000I0.000J4.850
G3X0.000Y4.850I-4.850J0.000
G1X0.000Y5.850
G3X-5.850Y0.000I0.000J-5.850
G3X0.000Y-5.850I5.850J0.000
G3X5.850Y0.000I0.000J5.850
G3X0.000Y5.850I-5.850J0.000
G1X0.000Y6.850
G3X-6.850Y0.000I0.000J-6.850
G3X0.000Y-6.850I6.850J0.000
G3X6.850Y0.000I0.000J6.850
G3X0.000Y6.850I-6.850J0.000
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-0.297F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-0.445F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-0.593F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-0.741F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-0.890F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-1.038F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-1.186F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-1.334F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-1.483F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-1.631F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-1.779F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-1.928F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-2.076F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-2.224F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-2.372F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-2.521F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-2.669F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-2.817F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-2.966F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-3.114F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-3.262F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-3.410F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-3.559F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-3.707F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-3.855F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-4.003F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-4.152F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-4.300F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-4.448F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-4.597F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-4.745F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-4.893F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-5.041F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-5.190F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-5.338F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-5.486F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-5.634F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-5.783F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-5.931F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-6.079F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-6.228F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-6.376F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-6.524F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-6.672F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-6.821F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-6.969F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-7.117F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-7.266F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-7.414F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-7.562F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-7.710F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-7.859F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
G1X0.000Y6.850
G0Z1.000
G0X0.000Y0.850
G0Z0.000
G1Z-8.007F300.0
G1X0.000Y1.850
G1X0.000Y2.850
G1X0.000Y3.850
G1X0.000Y4.850
G1X0.000Y5.850
