Copyright issue
I have modelled up the "Meta Quest 2 interchangeable facial interfaces" after a 3D scan.
Will there be any issue to share those files here due to copyright claims?
Accepted answer
Yes, there will be an issue.
Please do not upload such models.
Otherwise we will definetely receive a DMCA request from Meta.
From https://help.grabcad.com/article/149-community-values-and-guidelines?locale=en :
> Do not use copyrighted company / product logos in your model designs unless you are the rights-holder, or have been given permission by the rights-holder. Models with logos used without permission are subject to removal by GrabCAD Support.
1 Other answer
If you feel the need to ask then you already know the answer. What is the purpose of sharing? So that someone can make a physical copy? I can’t think of a single reason why someone would legitimately require a scanned copy. Most assuredly these are copyrighted or patented. Sharing a scanned copy is definitely against copyright.
While there are those that might suggest it’s okay to share because you’re not likely to get caught, I would suggest you to what’s right and honorable and not share the files.
