Dow do convert downloaded files into common importable format like OBJ FBX or IGES?
For import into Rhino3D
Crossemanager is a software converter, that's works on most of the format. Otherwhise most cad file can export import from this main format, IGES is oudated I believed and FBX bellongs to autdesk, so you should probably own an autodesk software to convert this format.
