help me - Convert IPT(inventor 2022) to STP le van hung 9 Sep, 2022 02:15 PM I can't open file ipt with inventor2021. Does anyone help me? Part12.ipt Part5.ipt Part4.ipt Part2.ipt Part3.ipt Accepted answer Carlos J. Veloso Answered on 9 Sep, 2022 03:21 PM You should be able to upload the file using your Autodesk Inventor, and then export as .step file. I was able to do it with Autodesk Fusion 360. See the attached. Part2 v1.step Part3 v1.step Part5 v1.step Part4 v1.step Part12 v1.step 1 Other answer manikandan smk Answered on 14 May, 2024 11:02 AM kindly convert to this ipt in to stp STEP.ipt
