How can I get standard Impeller designs?
Hi all,
I'm working currently on my undergrad thesis project, which is manufacturing stainless steel turbocharger impeller using wire-arc additive manufacturing. The problem is that I cannot find standardized impeller designs or working drawings anywhere. I found a lot of impressive 3d models here, but the authors did not attach any related information whatsoever. Is there a way I can find impeller drawings for manufacturing with some information about the application conditions, etc?
Compressors are of iterative design process, driven by parameters like... flow rate, rotational speed, fluid & fluid density, pressure delta, etc..
You can get a trial version of CFturbo and that would be my recommendation. Study a bit before hand, know what your performance requirements are, so you can hit the ground running.
