how can i make a c-axis turning mill/turn program in master-cam?
I have a problem while making a mill/turn profile of an 3d object in master-cam.
I want to make toolpath for this 3D object.
I have tried different methods to move on; but none worked.!
My m/c is a turn-o-mill turning machine with only c-axis enabled( with GE fanuc control).
My main objective is to manufacture a crank shaft(soon, i will upload the same.); but my problem will be solved with this example.
Thanks Mandeep.
