how to add commands to joints in DMU kinematics CATIA V5 ..? i tried but dono how to add...:( Praveen kumar E 24 Mar, 2013 10:18 AM please give some examples using point& curve joint in Kinematics 1 Answer richardphat Answered on 24 Mar, 2013 07:41 PM Hi, points & curve in DMU kinematics only work if the points is already coincident with the curve. It will not be able to enable the feature you are trying to do if the requirement is not met.
