how to add edge band in furnitue design ?
In my job, I am making the cutting list only with proper information about any necessary edge lipping.
Automatically generates the cutting list. In my example, I used the board. You can use this method for the rod, circle, tube, or whatever you want.
First step.
You have to open the te File Properties (Cutting List Step 01.jpg)
Second step.
Open Configuration Specific tab (Cutting List Step 02.jpg)
Third step.
Edit List button lets you make the name what you want (Cutting List Step 03.jpg)
Fourth step.
You can now select from Property Name the name that you want and connect with the right dimension regarding the name.
(Cutting List Step 02.jpg) and (Cutting List Step 02.jpg)
Fifth step.
Make the drawing with your board. (Cutting List Step 05.jpg)
Sixth step.
Generate the Bill of Material. When you don't set up before you must connect any cell with proper information about the board. (Cutting List Step 06.jpg)
That's it.
