How to adjust shore hardness on J750 Polyjet printer?
On GrabCAD Print, using the J750 PolyJet printer. What are the tray materials, support materials, and relevant settings needed to have the menu to adjust the shore hardness become available?
1) you would need to have at least 1 flexibe materal and 1 rigid material loaded (eg Agilus30 Black & VeroBlack
2) Import the model and orientate onto the build tray
3) go to model setting
4) Select digital materials from the drop down list
5) Select the materials to be combined (eg agiluis30 black and vero black)
6) Select the desired shore value
