how to animate in solid edge st5 zyd 25 Aug, 2013 06:56 PM animation in solid edge by using motor/ ERA COMMAND 1 Answer jacksonbenom93 Answered on 24 Mar, 2016 04:39 AM Currently, I'm using ST8, Before doing this you must have an assembly with one degree of freedom on your rotating part. You can go to home=> motors and pick the necessary drive and make your model to simulate.
