How to connect wire rope from pulley to another pulley in fusion 360? Muhammad Haiqal 29 Jun, 2021 08:07 PM I have been struggling to make a rope wire that can joint between winch to the pulley and to another pulley 1 Answer Nehul Dhameshiya Answered on 3 Jul, 2021 07:36 AM CREATE WIRE BY SKETCH USING LINES, ARC, SPLINTS, (CHOOSE ACCORDING TO WIRE TENSION YOU NEED). FINISH SKETCH. USE SWEEP OR PIPE COMMAND (GIVE THE DIAMETER OF THE WIRE YOU NEED). APPLY SOME WIRE TEXTURE ON THE SWEPT BODY BY APPEARANCE COMMAND.
