How to create a project file and add another path which is not in that folder Ben Elliott 27 Mar, 2019 03:57 AM How do you add a path in a project so when I open an assembly, parts are not unresolved. project help.JPG 1 Answer Danny Key Answered on 3 Apr, 2019 07:27 AM Hoi Ben, you can add a new path by opening you project. Then you select the project where the new path is needed. Next you select " Libraries " , the right click, and add path, or add paths from files. See the attacht pdf. Regards, Danny Add Path.pdf
