How to create Rib on cylindrical part
9 Answer
there are more then 100 methods...
If this rib is a triangle in sketch, meka a trapeze (rectangle + triangle), the triangle part of the trapeze is autside the cylinder, and the rectangle part is inside the cilindre.
Or creta it so as in the picture, and thick the face inside the cilindre (winth Thickness)...
hI vijay,
Here i attached the cad part with history, please go through it. i hope its fulfill you expectation.
regards
Vinoth
Answered with a tutorial: https://grabcad.com/tutorials/how-to-create-rib-on-cylindrical-part--1
i hope this helps
