How to do the edge fillet in Knuckle joint in CATIA Kaviyarasu Manoharan 9 Dec, 2017 08:39 AM I got stuck in the final stage of part design of Knuckle joint where you use the fillet to make a curved edge between the octagon and the square. How to do it in CATIA knuckle2.JPG knuckle.JPG knuckle2.JPG knuckle.JPG 1 Answer Vũ Đạt Answered on 9 Dec, 2017 09:15 AM if you can't use command fillet, i think you should use command pocket with circle
