How to do the replace command in catia v5
the replace too is used to replace one element with other such as a sketch for a sketch, surface for surface, aixs for axis
to use the tool simply right click on the element you want to replace click replace and then select the element you wish to replace it with (See images)
Answered with a tutorial: https://grabcad.com/tutorials/how-to-do-the-replace-command-in-catia-v5
