how to draw 500 diameter duct in inventor in different angles and different heights?
If you are using sheet metal, I would suggest using the "Lofted Flange" tool inside of the Inventor Sheet Metal tools. However, if you are modeling for other reasons, for instance 3D space planning, I would create a 2D sketch of the cross sectional profile for the duct work and then a 3D sketch for the duct path. Then you could use the "Sweep" command to create the required duct work. If you have any questions, please do not hesitate to contact me. Hope all is well and have a most blessed night!
Peace,
Pete
