How to learn advanced mould design using Cimatron?
i am working as tool room designer for two years and i want to learn advance in mould design using cimatron.
2 Answer
To be a good mould designer cimatron is just another tool. mould design knowledge is the key to being a good designer. Soak up a much information as you can from the others working around you.
