HOW TO MAKE A DRAWING OF THE SHAFT SHOWING THE MOUNTING OF THE BEARINGAND THE DESIGN OF THE HUB. rashid 31 Jul, 2013 09:11 PM THE ONLY IMPORTANT DETAIL REQUIRED OF THE HUB IS MOUNTED TO THE AXLE 1 Answer a1ce339a Answered on 1 Aug, 2013 01:52 AM i THINK YOU NEED TO LEARN THE PROGRAM FIRST. AND 2ND YOU REALLY CANT UNDESTAND WHAT IT IS YOU WANT. What Shaft? What bearing? What Hub?
