how to make chain assembly in catia
there is no quick way that i know to do this, when i have had to do this task i use a master part with the center curve for the chain and then use points along this curve to set the center points of the pins. Unfortunately from there it is a lot of assembly constraining, If you do find a more elegant method i would be very interested
thanks C Malia
