sir,
I want to show rubber pipe in 3D model& straight pipe in drafting, but i don't want to add straight pipe for drafting, pls solve my this problem........
Model the rubber hose in routing application and then you can add "Routing Bill of Material" to draft sheet which shows the cut length. That way you don't need a model of the hose in straight position.
