How to model tool head of shaper machine, connecting rod & tailstock of lathe in Solid Edge
This is a question with no answer.
If you are a designer, use your 3d modeling programs and skills and design what you want. The only thing whats holds you back from building a great model is that you do not know how to do it in solid edge, but i believe that the model is already build in your head.
The best thing to do is just do it and in the process you learn the program.
Succes....
