how to use add existing curves option in NX-CAD
give me an example
maybe this link will help
http://www.eng-tips.com/viewthread.cfm?qid=284194
good luck!
check these files
what do you want to do with that option ??? what is the use of it, i had tried alitle to use it but nothing to me too, maybe we can came with something to do the same thing diferent way,
ok open a project of yours
enter in a new sketch
when u will be able to select "add existing curves" picture 1
after that i stand still, because i cannot select anything picture 2
Hi siva
first you extract curve which you want ,n project it on selected plan then go to sketch mode..so in that you can use ADD Existing curve command
