How to use helical sweep cut to make threads in Pro-E\Creo ??
Its easy to use helical sweep to cut threads in proe or creo elements...
I've selected a normal bolt...you can find a variety of them in library....
Ok lets get started...
Used a simple bolt....
Answered with a tutorial: https://grabcad.com/tutorials/how-to-use-helical-sweep-cut-to-make-threads-in-pro-e-creo
I am having problem in defining sweep profile in step 6 above. Nothing is happening in pro e wildfire.
In creo 2.0 the procedure is slighty different (justs because menu are different) but anyway this tutorial helped me a lot! :)
Great work and thanks to share this tutorial with us!
THANKS!
