how to use manikin in proe
to find clearence betwn driver n cage
Well you tagged this question as CATIA, so i can answer you how to measure clearance between manikin and cage in CATIA. Find toolbar called "Space Analysis". When you locate that toolbar, click on tool called "Distance and Band Analysis", and then select, for example, manikin head and top bar....
